[QGIS-trac] [Quantum GIS] #3326: Symbolization - Applying/OK new symbol qualities
Quantum GIS qgis at qgis.org
Mon Dec 13 05:27:23 EST 2010
   Reporter:  marsofearth                                |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Build/Install                              |            Version:  1.6.0
   Keywords:                                             |   Platform_version:
   Platform:  OS X                                       |           Must_fix:  Yes
Status_info:  0                                          |
 Using QGIS 1.6.0 SnowLeopard version with Kyng's Frameworks
 I have tried many different shapefiles that seem to work fine in UDIG,
 GRASS, and ArcGIS.
 QGIS hard crashes when I try to change the Symbolization of a feature in
 the PROPERTIES pane. Clicking APPLY or DONE hard crashes QGIS
 I have re-installed QGIS and wiped any previous caches and .plist files
 from no difference.
 10.6.5
 Intel Macintosh iMac 24" 3ghz c2d
 4gbram
 ran memtest (just incase) memory is clear and fine.
 ran fdisk file system is fine, no bad blocks etc.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3326>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
