[QGIS-trac] [Quantum GIS] #3329: Error for postgres's provider when table(statement SELECT ) is outside public's schema
Quantum GIS qgis at qgis.org
Mon Dec 13 20:36:05 EST 2010
public's schema
   Reporter:  lmotta                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Data Provider                     |            Version:  1.6.0
   Keywords:                                    |   Platform_version:
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 When used layers outside public's schema has problem where layer is
 defined with statement SQL.
 The problem is message of error, but, the layer is created  correct.
 Menssage Error:
 SQL: declare oidcursor binary cursor for select regclass...
 The example of layer:
 dbname='postgis' host=localhost port=5432 user='postgres' key='gid'
 table="(select l.id AS gid, l.the_geom AS the_geom from
 gis.tl_20101117_101056_limite l)" (the_geom) sql=
 When layer are in public's schema is OK.
 ... from public.tl_20101117_101056_limite l
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3329>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
