[QGIS-trac] Re: [Quantum GIS] #3030: Query Builder in Properties produces "Query Failed"
Quantum GIS qgis at qgis.org
Fri Dec 17 04:23:11 EST 2010
        Reporter:  alobo                             |         Owner:  jef
            Type:  bug                               |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.6.0
       Component:  Vectors                           |       Version:  1.6.0
      Resolution:                                    |      Keywords:
Platform_version:  ubuntu 9.10                       |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Changes (by qgisviti):
  * status:  closed => reopened
  * version:  Trunk => 1.6.0
  * resolution:  upstream =>
Comment:
 Replying to [comment:10 alobo]:
 > Confirmed: renaming coords.x1 and coords.x2 to coordsx1 and coordsx2
 solves the problem.
 > Has the problem been reported to OGR developers?
 > Shouldn't QGIS have a warning for attributes names including "."
 meanwhile?
 > Agus
 I still have problem with query builder in properties even if the name of
 columns doesn't have any dots. My field name is "NDVI" and when I use
 Qgis, I double click in the appropriate Fields, Operator and Value entries
 in qgis and it's written "NDVI">=0.06: the error "The subset string could
 not be set" is returned.
 It works well from Attribute Table/Advanced? Search
 So the problem may be more than dots in name of fields...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3030#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
