[QGIS-trac] Re: [Quantum GIS] #2733: fTools Add geometry column fails to add XCOORD if source is GPX file or PostGIS Layer (was: fTools Add geometry column fails to add XCOORD if source is GPX file)
Quantum GIS qgis at qgis.org
Fri Dec 17 05:14:11 EST 2010
PostGIS Layer
   Reporter:  marisn                            |              Owner:  cfarmer
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Python plugins and bindings       |            Version:  Trunk
   Keywords:  ftools                            |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
Changes (by hdus):
 * cc: horst.duester@… (added)
  * must_fix:  No => Yes
Comment:
 I found the same behaviour with PostGIS layers as well. The bug depends on
 the position of the geometry column in the column-list.
 With the following POINT table-definition, geometry column at the
 beginning of the columns list:
 CREATE TABLE test1
   id serial NOT NULL,
   wkb_geometry geometry,
   feld1 text,
   feld2 text,
   feld3 integer,
   CONSTRAINT test1_pkey PRIMARY KEY (id)
 only the YCOORD column will be exported.
 With the following POINT table-definition, with geometry at the end of the
 columns list:
 CREATE TABLE test1
   id serial NOT NULL,
   feld1 text,
   feld2 text,
   feld3 integer,
 all columns XCOORD and YCOORD will be exported fine.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2733#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
