[QGIS-trac] [Quantum GIS] #3356: Error when spatialite select statement returns only one field
Quantum GIS qgis at qgis.org
Sun Dec 19 22:10:27 EST 2010
   Reporter:  brushtyler                                 |              Owner:  brushtyler
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Data Provider                              |            Version:
   Keywords:                                             |   Platform_version:
   Platform:  All                                        |           Must_fix:  Yes
Status_info:  0                                          |
 From lmotta (see #3139):
 When in select statement have only the pkuid's column, the attributes's
 table didn't showed the values of pkuid. Obs: The identify is OK. The
 problem is the table of layer Otherwise (have others columns) all
 attributes showed in table
 Example with error(only pkuid): sql = "select t.id as pkuid,t.the_geom as
 geometry from test t limit 10" uri = QgsDataSourceURI()
 uri.setDatabase('/home/lmotta/bd_gis/spatialite/gis.sqlite')
 uri.setDataSource(, '(%s)' % sql, 'geometry', , 'pkuid')
 qgis.utils.iface.addVectorLayer(uri.uri(), "Select", 'spatialite')
 Example correct (more columns): sql = "select t.id as pkuid, t.name,
 t.the_geom as geometry from test t limit 10" ...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3356>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
