[QGIS-trac] Re: [Quantum GIS] #3222: Fast, easy and beautiful on the fly rule-based rendering of OSM maps
Quantum GIS qgis at qgis.org
Mon Dec 27 17:52:27 EST 2010
   Reporter:  mayeulk                           |              Owner:  wonder
       Type:  patch                             |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Symbology                         |            Version:
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Comment(by wonder):
 Hi Mayeul,
 thanks for the patch. I had a brief look at it and I like some parts of it
 Personally I think it would be good to separate the patch to "safe" and
 "unsafe" part. Things like support for rule label and description could be
 committed immediately, however the changes related to symbol levels are
 unstable and should be given more time to settle down.
 Regarding the symbol levels, I do not like the approach with merging of
 the symbols. I have in mind some improvements to renderer interface that
 would solve it: instead of calling renderer's symbolForFeature() when
 rendering with symbol levels, the draw() method from QgsVectorLayer would
 let renderer to connect more symbols with a feature. I will try to work on
 this in the following days/weeks.
 In the meanwhile, if you attach a newer version of the patch that leaves
 out the changes regarding symbol levels, I would be happy to apply it in
 case there are no problems.
 Martin
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3222#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
