[QGIS-trac] [Quantum GIS] #2408: Identifiable layers not saved correctly if sorted before choosing
Quantum GIS qgis at qgis.org
Tue Feb 2 19:04:03 EST 2010
   Reporter:  sowelu                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.5.0
  Component:  GUI                               |            Version:  HEAD
   Keywords:  identifiable layers               |   Platform_version:  Kubuntu 9.10
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 If you sort the layers by type before or after checking the ones you want
 to be identifiable, then the results are not read correctly when the
 dialog is dismissed with OK.
 1) Load some raster layers
 2) Load some vector layers
 3) Settings->Project Properties->Identifiable layers
 4) Click Type heading to sort.
 5) Check all vectors, uncheck all rasters
 6) OK
 7) Go back into Settings->Project Properties->Identifiable layers and see
 that they have changed.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2408>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
