[QGIS-trac] Re: [Quantum GIS] #2078: [Windows] adding a GRASS raster created with r.external crashes QGIS
Quantum GIS qgis at qgis.org
Fri Feb 5 07:05:48 EST 2010
        Reporter:  pcav                                       |         Owner:  rugginoso
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Windows
        Must_fix:  No                                         |   Status_info:  0
Comment (by rblazek):
 Replying to [comment:5 lutra]:
 > Tested r12883 under XP and still crashes.
 Thanks for testing.
 > The curios thing is that qgis crashes if you try add the raster from the
 grass browser but doesn't crash if you add the raster from the qgis grass
 toolbar.
 That is OK, I just forgot to use the new driver also in browser and
 module, fixed in r12885.
 > Nevertheless the raster doesn't show correctly and qgis shows the
 following message:
 > Cannot draw raster
 > Cannot start module
 > command: C:/OSGeo4W/apps/qgis-dev/./grass/modules/qgis.d.rast.exe
 map=teste1 at demo
 window=-7.1176e+06,1.33306e+06,4.89704e+06,7.80968e+06,1170,631<br><br>ERRO:Unable
 to locate symbol <GDALAllRegister>
 It seems that GRASS libs are compiled with GDAL but the module
 qgis.d.rast.exe was not compiled with GDAL libs. I have added GDAL_LIBRARY
 into CMakeLists.txt in r12886.
 > The resulting raster is all grey and in the properties shows no color
 bands.
 It just draws the gray rectangle if the GRASS module fails.
 No we have to wait until tomorrow for the new build.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2078#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
