[QGIS-trac] Re: [Quantum GIS] #2078: [Windows] adding a GRASS raster created with r.external crashes QGIS
Quantum GIS qgis at qgis.org
Fri Feb 5 12:13:17 EST 2010
        Reporter:  pcav                                       |         Owner:  rugginoso
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Windows
        Must_fix:  No                                         |   Status_info:  0
Comment (by rblazek):
 Replying to [comment:9 lutra]:
 > To test I used the "landcover.img" raster in the qgis demo dataset.
 landcover.img? Aren't we talking about GRASS? I am testing with gtopo30
 from demo mapset in alaska GRASS location from demo dataset.
 > PS I'm available to further tests as many times as necessary, but I will
 need a little insight about Dbgview.exe in order to produce outputs that
 can help solve this problems.
 You can try to just get working the C:/OSGeo4W/apps/qgis-
 dev/grass/modules/qgis.d.rast.exe from GRASS shell and check with
 something like ldd and nm for Windows why GDALAllRegister cannot be found.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2078#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
