[QGIS-trac] Re: [Quantum GIS] #1945: [Vista] Qgis crashes removing GRASS raster layer from map canvas
Quantum GIS qgis at qgis.org
Fri Feb 5 13:48:50 EST 2010
        Reporter:  juanelz                                    |         Owner:  rugginoso
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  GRASS rasters
Platform_version:  Vista                                      |      Platform:  Windows
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by lutra):
 Back to the original problem:
 (under Vista) using the mapset in the qgis demo dataset I notice that if
 the the raster is added trough the qgis GRASS toolbar, then removing it
 from the legend do not causes a crash. If the same raster is added via the
 GRASS browser, then when removed from the legend qgis always crashes, even
 if you meanwhile close de mapset.
 Seems to confirm no problems under xp.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1945#comment:20>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
