[QGIS-trac] Re: [Quantum GIS] #1945: [Vista] Qgis crashes removing GRASS raster layer from map canvas
Quantum GIS qgis at qgis.org
Fri Feb 5 19:35:14 EST 2010
        Reporter:  juanelz                                    |         Owner:  rugginoso
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  GRASS rasters
Platform_version:  Vista                                      |      Platform:  Windows
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by lutra):
 Replying to [comment:21 rblazek]:
 > Isn't it bug in the plugin? Should not they check 'if cstr'? Where can I
 find the plugin?! I cannot find it on internet. The installer in QGIS is
 currently disabled. I have to see which values it reads and if they can be
 passed from the provider with current raster providers implementation.
 the "value tool" plugin is in the contributed repository, available among
 all the others. As far as I can remember it always worked fine with GRASS
 rasters. In fact it is one of that tools we use more when we reclassify
 rasters (and  show how to), use r.mapcalc, etc.
 > Does it work with WMS layer?
 as far as I know, no.
 > I have fixed it in the module so that it returns null. It is also called
 by valuetool?
 > The provider method is called by  QgsRasterLayer::identify and the
 results
 > map does not seem to be expected to contain any particular data, just
 readable info.
 You may want to ask this in the dev mailing list.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1945#comment:24>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
