[QGIS-trac] Re: [Quantum GIS] #2410: field calculator results may violate spatialite type contraints
Quantum GIS qgis at qgis.org
Sun Feb 7 13:05:55 EST 2010
        Reporter:  anitagraser       |         Owner:  nobody
            Type:  bug               |        Status:  new
        Priority:  minor: annoyance  |     Milestone:  Version 1.5.0
       Component:  GUI               |       Version:  HEAD
      Resolution:                    |      Keywords:  spatialite, editing
Platform_version:                    |      Platform:  All
        Must_fix:  No                |   Status_info:  1
Changes (by lutra):
 * cc: esseffe (added)
Comment:
 A few notes (tested on both linux and xp with qgis trunk and the
 spatialite sample dataset):
 *) add a spatialite vector, open attributes properties and add a column.
 Save changes. If you open the attribute table the new column do not show
 (not even in the field calculator). You need to remove the layer and add
 it again to see the new column (and be able to populate it).
 *) as consequence if you add spatialite layer, toggle editing, open the
 field calculator and try to populate a new column, qgis will fail
 Could not commit changes to layer Towns
 Errors: SUCCESS: 1 attribute(s) added.
   ERROR: 8101 attribute value change(s) not applied.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2410#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
