[QGIS-trac] [Quantum GIS] #2425: page setup problems MacOS
Quantum GIS qgis at qgis.org
Tue Feb 9 13:12:54 EST 2010
   Reporter:  vrgsmm01                          |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.5.0
  Component:  Printing                          |            Version:  HEAD
   Keywords:  page setup                        |   Platform_version:
   Platform:  OS X                              |           Must_fix:  Yes
Status_info:  0                                 |
 When you try to print from the composer...if the layout paper is bigger
 than A4
  ...print result is out of range.
 This problem can be fixed by adding an additional menu idem "page setup"
 in macos version
 otherwise can't print layouts in plotter...because page setup doesn't work
 properly.
 In version 0.74 the page setup is working perfectly...because if the
 composer map paper is different from the
 printing paper...the "page setup dialog" is appearing asking you to choose
 the appropriate page and printer for printing!
 Now...in current version 1.4 this feature is not present...why???
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2425>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
