[QGIS-trac] Re: [Quantum GIS] #1945: [Vista] Qgis crashes removing GRASS raster layer from map canvas
Quantum GIS qgis at qgis.org
Wed Feb 10 10:39:48 EST 2010
        Reporter:  juanelz                                    |         Owner:  rugginoso
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  GRASS rasters
Platform_version:  Vista                                      |      Platform:  Windows
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by lutra):
 Hi Radim,
 I just compiled r12917 under linux and I still see the colorbands problem
 (see the last attached image).
 I also noticed another thing that may found interesting:
 in qgis trunk (not in 1.4) when using the identify tool on a cell of a
 GRASS raster that has a NULL value, then the value -2147483648 is shown
 instead.
 I would also underline that your new driver has solved a nasty bug related
 to GRASS rasters under windows that passed unnoticed until today:
 open a mapset and add a GRASS raster (in qgis 1.4)
 use the identify tool/ruler/etc.
 close the mapset
 pass the tool over the map canvas
 a warning is issued saying that the mapset is not defined
 at this stage if you try to exit QGIS the program will crash
 The actual problem with GRASS rasters has nothing to do with the original
 ticket, do you want me to open a new one?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1945#comment:33>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
