[QGIS-trac] Re: [Quantum GIS] #2444: Discrepancy between gdalinfo and QGIS raster metadata
Quantum GIS qgis at qgis.org
Mon Feb 15 07:03:15 EST 2010
        Reporter:  alobo                             |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Rasters                           |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Comment (by mmassing):
 Looking at the sample file you provided, I think the issue here is that
 the generated .tif
 is not north-up (i.e. the geotransform contains a non-zero rotational
 component or, in this case, a positive scale factor for the y-axis).
 Such coordinate systems are perfectly valid, but some software may not  be
 prepared to handle
 this general case.
 QGis handles this type of files by reprojecting them on the fly (using the
 gdal VRT
 mechanism). Other applications which do not explicitly support a
 rotated/flipped coordinate
 system may require you to warp the input file into a north-up orientation
 (e.g. by using "gdalwarp test2.tif test2-nu.tif", or by wrapping it in an
 appropriate
 VRT file).
 Manuel
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2444#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
