[QGIS-trac] Re: [Quantum GIS] #2336: loading a project from the command line results in broken rendering
Quantum GIS qgis at qgis.org
Fri Jan 1 14:06:26 EST 2010
        Reporter:  ricardogsilva                     |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Project Loading / Saving          |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:  Ubuntu 9.10                       |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Comment (by ricardogsilva):
 It seems that this issue is related to the state of the qgis main window.
 I am usually working with qgis's window maximized. Now I noticed that if I
 load the project from the command-line and then hit the unmaximize button,
 the window gets shorter (as expected) and also the rendering is back to
 normal. If I then go back to a maximized window everything works fine. I
 think the project gets loaded before the window is maximized, and that
 causes the rendering to become messed up.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2336#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
