[QGIS-trac] [Quantum GIS] #2348: Overview map in composer
Quantum GIS qgis at qgis.org
Thu Jan 7 14:15:24 EST 2010
   Reporter:  jctull                                     |              Owner:  mhugent
       Type:  enhancement                                |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.5.0
  Component:  Build/Install                              |            Version:  HEAD
   Keywords:  composer overvew map                       |   Platform_version:
   Platform:  All                                        |           Must_fix:  No
Status_info:  0                                          |
 It would be helpful to be able to place the overview map in the composer.
 Ideally, you could adjust it (move around, change extents, etc., because
 sometimes the overview map is not exactly right). Currently, to create a
 locator map, I have to add it as a separate map item, which is not a big
 problem. Unfortunately, every time a new layer is added to the canvas,
 this "locked" map goes blank and has to be updated with the appropriate
 layers selected in the canvas. Going through this process made me think
 that the overview map is really all I want. Being able to add it to the
 composer would eliminate the need to create a boundary polygon as well.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2348>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
