[QGIS-trac] Re: [Quantum GIS] #1959: Trunk build fails with sip-4.9 and PyQt-4.6
Quantum GIS qgis at qgis.org
Fri Jan 8 14:17:53 EST 2010
        Reporter:  jctull                                     |         Owner:  nobody
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.4.0
       Component:  Build/Install                              |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  sip pyqt compile
Platform_version:  10.6.1                                     |      Platform:  OS X
        Must_fix:  Yes                                        |   Status_info:  0
Comment (by micha):
 Compiling '''qgis 1.3''' on Fedora 12, I came across the same bug. The
 version of sip supplied on Fedora 12 is 4.9.3 .
 Changing the conversions.sip file as suggested above solved the problem,
 and 'make' completed successfully.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1959#comment:10>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
