[QGIS-trac] Re: [Quantum GIS] #2342: qgis crashes when using the "merge selected features" tool
Quantum GIS qgis at qgis.org
Sat Jan 9 09:02:51 EST 2010
        Reporter:  gespiel                                    |         Owner:  mhugent
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  Digitising                                 |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by gespiel):
 Hello,
  Befor I opened this new ticket, i had first tested the attached
 vectorlayer also with ftools "check geometrie" and it was ok.
 The problematic object in the layer seems to be nr 97 (97 in the dbf,
 field NR.)You can`t merge it with other objects.
 Gerhard
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2342#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
