[QGIS-trac] Re: [Quantum GIS] #2028: [Vista] GRASS plugin crashes QGIS when running the r.colors, r.null, v.dissolve modules
Quantum GIS qgis at qgis.org
Sat Jan 9 12:23:35 EST 2010
v.dissolve modules
        Reporter:  pcav                                       |         Owner:  rugginoso
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Windows
        Must_fix:  No                                         |   Status_info:  0
Comment (by lutra):
 Tested under Vista 32 bit with qgis 1.4.
 Opened the grass location available in the qgis sample dataset, added the
 raster available in the "demo" mapset.
 When applying r.colors.table qgis crashes and dgbview returns
 [3820] d:\progs\c\qgis-
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1014) :
 (QgsGrassModule::pixmap) path = C:/OSGeo4W/apps/qgis-
 dev/./grass/modules/r.colors.table
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1130) :
 (QgsGrassModule::run) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(791) :
 (QgsGrassModuleStandardOptions::ready) entered.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(2528) :
 (QgsGrassModuleInput::ready) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(2532) :
 (QgsGrassModuleInput::ready) count = 2
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1962) :
 (QgsGrassModuleOption::ready) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(940) :
 (QgsGrassModuleStandardOptions::requestsRegion) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(2220) :
 (QgsGrassModuleInput::useRegion) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(956) :
 (QgsGrassModuleStandardOptions::usesRegion) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(971) :
 (QgsGrassModuleStandardOptions::usesRegion) NO usesRegion()
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(600) :
 (QgsGrassModuleStandardOptions::checkOutput) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(609) :
 (QgsGrassModuleStandardOptions::checkOutput) opt->key() = color
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(765) :
 (QgsGrassModuleStandardOptions::output) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(774) :
 (QgsGrassModuleStandardOptions::output) opt->key() = color
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1222) :
 (QgsGrassModule::run) mOutputVector.size() = 0
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1224) :
 (QgsGrassModule::run) mOutputRaster.size() = 0
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1233) :
 (QgsGrassModule::run) option: map=gtopo30 at demo
 (QgsGrassModule::run) option: color=byg
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1263) :
 (QgsGrassModule::run) command: r.colors map=gtopo30 at demo color=byg
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(56) :
 (QgsGrassModule::findExec) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(626) :
 (QgsGrassModuleStandardOptions::freezeOutput) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(635) :
 (QgsGrassModuleStandardOptions::freezeOutput) opt->key() = color
 [2076] Invalid parameter passed to C runtime function.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1434) :
 (QgsGrassModule::readStderr) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1377) :
 (QgsGrassModule::finished) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(1379) :
 (QgsGrassModule::finished) exitCode = 0
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(695) :
 (QgsGrassModuleStandardOptions::thawOutput) called.
 build\src\qgis\qgis_unstable\src\plugins\grass\qgsgrassmodule.cpp(704) :
 (QgsGrassModuleStandardOptions::thawOutput) opt->key() = color
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(212) :
 (QgsMapRenderer::render) ========== Rendering ==========
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(236) :
 (QgsMapRenderer::render) Starting to render layer stack.
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(323) :
 (QgsMapRenderer::render) Rendering at layer item gtopo3020100109171834210
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(331) :
 (QgsMapRenderer::render) If there is a QPaintEngine error here, it is
 caused by an emit call
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(342) :
 (QgsMapRenderer::render) Rendering layer gtopo30
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(343) :
 (QgsMapRenderer::render)   Layer minscale 0
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(344) :
 (QgsMapRenderer::render)   Layer maxscale 1e+08
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(345) :
 (QgsMapRenderer::render)   Scale dep. visibility enabled? 0
 build\src\qgis\qgis_unstable\src\core\qgsmaprenderer.cpp(346) :
 (QgsMapRenderer::render)   Input extent:
 -7117600.0000000000000000,1367760.0000000000000000 :
 4897040.0000000000000000,7809680.0000000000000000
 build\src\qgis\qgis_unstable\src\core\raster\qgsrasterlayer.cpp(1418) :
 (QgsRasterLayer::draw) entered. (renderContext)
 build\src\qgis\qgis_unstable\src\core\raster\qgsrasterlayer.cpp(1424) :
 (QgsRasterLayer::draw) checking timestamp.
 build\src\qgis\qgis_unstable\src\core\raster\qgsrasterlayer.cpp(5423) :
 (QgsRasterLayer::update) entered.
 build\src\qgis\qgis_unstable\src\core\raster\qgsrasterlayer.cpp(482) :
 (QgsRasterLayer::lastModified)
 name=C:/Users/gio/Downloads/qgis_sample_data/qgis_sample_data/grassdata/alaska/demo/cellhd/gtopo30
 build\src\qgis\qgis_unstable\src\core\raster\qgsrasterlayer.cpp(544) :
 (QgsRasterLayer::lastModified) last modified = Sat Jan 9 17:19:48 2010
 build\src\qgis\qgis_unstable\src\core\raster\qgsrasterlayer.cpp(5427) :
 (QgsRasterLayer::update) Outdated -> reload
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2028#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
