[QGIS-trac] Re: [Quantum GIS] #1095: 3-D GRASS line vectors from r.contour - Cant query or identify the lines, but can label the attributes
Quantum GIS qgis at qgis.org
Mon Jan 11 16:39:06 EST 2010
        Reporter:  dadudeman                         |         Owner:  rugginoso
            Type:  defect                            |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.3
       Component:  GRASS                             |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:  3D line vector, cant query identify
Platform_version:  Kubuntu 7.1                       |      Platform:  Linux
        Must_fix:  Yes                               |   Status_info:  0
Changes (by rblazek):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Yes, bug, I have fixed it in QGIS changeset:12738 but it is not perfect.
 QGIS is using Vect_select_lines_by_polygon and it is selecting lines using
 bbox of the passed polygon. I have just set z coors to
 -PORT_DOUBLE_MAX/PORT_DOUBLE_MAX to cover 3D. It should be better
 specified in GRASS how Vect_select_lines_by_polygon treats 3D vectors, but
 until they touch the function, it works in QGIS.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1095#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
