[QGIS-trac] Re: [Quantum GIS] #2271: print composer large format A0
Quantum GIS qgis at qgis.org
Fri Jan 22 14:55:58 EST 2010
        Reporter:  gespiel                           |         Owner:  ersts
            Type:  patch                             |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Printing                          |       Version:  1.3.0
      Resolution:                                    |      Keywords:
Platform_version:  XP sp3                            |      Platform:  Windows
        Must_fix:  Yes                               |   Status_info:  0
Comment (by gespiel):
 Replying to [comment:17 lutra]:
 > Replying to [comment:16 gespiel]:
 > > Hi Marco,
 > > have tested the pdf-print icon in the composer.
 > > Using A0-Format, Qgis crashes. (see attached jpg)
 > > I Use qgis 1.5.0-dev, rel. 12704 installed by OS4GeoW.
 > > Does this release content your patch?
 > > If not, how can I install the patch?
 > It seems that in r12809 changes have been made that can help solve your
 issues. In the next days (maybe already tomorrow) you should be able to
 install qgis-dev with osgeo4w including this code update. Please give it a
 try and leave feedback.
 Hello,
 have just installed r1281M and all is good. The pdf-print content the
 complete spatial images.
 Thank you verry much!!
 Gerhard
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2271#comment:18>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
