[QGIS-trac] Re: [Quantum GIS] #2395: GdalTools crash during install and on start
Quantum GIS qgis at qgis.org
Tue Jan 26 10:28:08 EST 2010
        Reporter:  sowelu                                     |         Owner:  brushtyler
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  Python plugins and bindings                |       Version:  HEAD
      Resolution:  invalid                                    |      Keywords:  gdaltools, python, plugin
Platform_version:  Kubuntu 9.10                               |      Platform:  Debian
        Must_fix:  Yes                                        |   Status_info:  0
Changes (by brushtyler):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [ticket:2395 sowelu]:
 > GdalTools plugin crashes QGIS when it is installed, and also prevents
 QGIS from starting. I am using the trunk version of both QGIS and GDAL on
 Kubuntu 9.10. If starting QGIS from the console the only message is 'Bus
 Error'.
 You're using the experimental version of the GdalTools-plugin, isn't it?
 Experimental plugins may have some problems and QGis doesn't recommend
 installing these unless for testing.
 If you purpose is not testing, you should disable experimental ones from
 the Python Plugin Installer.
 By the way, I opened a [https://trac.faunalia.it/GdalTools-
 plugin/ticket/42 New Ticket] on the GdalTools plugin trac and I'm closing
 this ticket.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2395#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
