[QGIS-trac] Re: [Quantum GIS] #2845: QGIS won't compile with python
Quantum GIS qgis at qgis.org
Sun Jul 11 06:59:02 EDT 2010
        Reporter:  Alexbit                           |         Owner:  timlinux
            Type:  patch                             |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:
       Component:  Python plugins and bindings       |       Version:  1.0.2
      Resolution:                                    |      Keywords:  python bindings
Platform_version:  Linux                             |      Platform:  Linux
        Must_fix:  No                                |   Status_info:  1
Comment(by jef):
 Replying to [comment:11 Alexbit]:
 > I've try the suggest patch here and on bug 2678 but they don't solve.
 > Moreover with google I've found some ideas but they got the same result.
 Are you sure you applied the patch correctly and did a clean rebuild?  The
 SIP detection problem should be fixed with the patch - at least it works
 just fine on sid here.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2845#comment:12>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
