[QGIS-trac] Re: [Quantum GIS] #2903: Segmentation Fault in 1.4, ubuntu karmic binaries
Quantum GIS qgis at qgis.org
Fri Jul 23 06:54:48 EDT 2010
   Reporter:  alobo                                      |              Owner:  jef
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.6.0
  Component:  Vectors                                    |            Version:  1.4.0
   Keywords:                                             |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  No
Status_info:  0                                          |
Comment(by alobo):
 Seems to be solved: The problem occurred with any vector layer and
 the reason was that actually no encoding was selected by default, the
 box was empty. Once UTF8 is selected, vector layers and projects open
 normally
 (UTF8 keeps selected as default).
 Actually, I do not know how to make that box empty again todouble check. I
 think that
 plugin points2one made that happen at crashing and from then on I could
 not
 open any vector layer again.
 Do you want me to do any further test using gdb to fully clarify the
 issue?
 Thanks!
 Agus
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2903#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
