[QGIS-trac] Re: [Quantum GIS] #2773: 30Meg GEOTIF does not display unless CRS matches
Quantum GIS qgis at qgis.org
Tue Jun 1 23:08:54 EDT 2010
        Reporter:  ScottParker                       |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Rasters                           |       Version:  HEAD
      Resolution:  invalid                           |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Changes (by jctull):
  * priority:  critical: causes crash or data corruption => major: does not
               work as expected
  * resolution:  => invalid
  * status:  new => closed
  * component:  Build/Install => Rasters
Comment:
 Unless I am misunderstanding your report, it sounds to me like you are
 trying to get a raster to reproject to a different crs than the file has.
 If so, this is not a bug. Qgis does not perform on-the-fly raster
 projection. If you meant something else, a little more detail is needed on
 the bug report.
 I closed this pending a different explanation of the problem,
 recategorized this as major and assigned it to the raster component.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2773#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
