[QGIS-trac] Re: [Quantum GIS] #2796: Labelling plugin: wrong printing result
Quantum GIS qgis at qgis.org
Wed Jun 9 11:06:30 EDT 2010
        Reporter:  trapanator                        |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  Printing                          |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by wonder):
 The labeling plugin has been moved to qgis application and its
 functionality is available from the "attributes" toolbar (the one with
 attribute table and measure tools) and from Layer menu.
 If you still see labeling plugin in your plugin manager, that's just a
 remainder from the older install. You can delete it as it is outdated.
 I can't replicate your problem, I believe it's happening to you only
 because you're using the old plugin. Please test again.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2796#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
