[QGIS-trac] Re: [Quantum GIS] #2691: v.db.what.connect.qgm broken
Quantum GIS qgis at qgis.org
Sat Jun 12 04:29:01 EDT 2010
   Reporter:  pcav                              |              Owner:  rugginoso
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.5.0
  Component:  GRASS                             |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Comment(by pcav):
 With r13709 it is better. No error, but no result:
 v.db.connect map=corine at PERMANENT =area =1 -p
 layer  table  in database  through driver  with key
 Vector map  is connected by:
 Successfully finished
 From the shell, the same command gives:
 GRASS_INFO_MESSAGE(6106,1): Vector map <corine at PERMANENT> is connected by:
 GRASS_INFO_END(6106,1)
 layer <1> table <corine> in database
 </home/grass/Toscana_corso/PERMANENT/dbf/> through driver <dbf> with key
 <cat>
 so the GRASS_INFO_END is apparently preventing the display of the relevant
 info.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2691#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
