[QGIS-trac] Re: [Quantum GIS] #2597: Adding layer is changed the last extent
Quantum GIS qgis at qgis.org
Sun Jun 13 04:10:52 EDT 2010
   Reporter:  aperi2007                         |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  MapCanvas                         |            Version:  HEAD
   Keywords:                                    |   Platform_version:  7
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
Comment(by aperi2007):
 Just tested with last version of qgis 1.5 trunk.
 Yes, I confirm it.
 I start qgis, uncheck the option
 "by default new layers added should be displayed" (to avoid time lost to
 rendering big archives).
 add a shapefile, and zoom to a big details on it. For example 1:2500.
 After I load a new shapefile (incidentally is the same shapefile).
 With this action the canvas change the visible extent settings it to the
 new extent (1:163.000)
 So I lost the specific point where I'm working :( .
 I think the new extent displayed is based on the merge of the two layers
 (incidentally are the same).
 This is quite boring, but with older version of qgis I hovewer could use
 the "zoom last" button to return to the original extent where the canvas
 was before to add the new layer (the bigger details). And this was a work-
 around to avoid lost the location where I'm working.
 Now qgis seem to reset the old-extent so the button "zoom last" is disable
 after added a new layer.
 So I think this is very unusable.
 The better choice is surely don't change the visible extent when adding a
 new layer, but if this is not possible a second choice is permit to use
 the "zoom last" button to return to the extent where I was working.
 Replying to [comment:6 pcav]:
 > Perhaps I did not understand, but I cannot confirm this misbehaviour.
 > Please aperi2007 test it again, if possible on a different machine, to
 see if we can close this.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2597#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
