[QGIS-trac] [Quantum GIS] #2823: Custom CRS doesn't work
Quantum GIS qgis at qgis.org
Fri Jun 18 07:33:51 EDT 2010
   Reporter:  stevehartley                      |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.5.0
  Component:  Build/Install                     |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  Windows                           |           Must_fix:  Yes
Status_info:  0                                 |
 When I've tried to define a custom CRS, the new CRS doesn't appear in the
 "User Defined Coordinate Systems" list when I try to use it.  When I
 return to the Custom CRS Definition window, the new CRS doesn't appear
 there either, just the ones I've defined in older versions of QGIS.  If I
 try to modify one of my custom CRSs, the modification doesn't appear in
 the "User Defined Coordinate Systems" list either.  Back in the Custom CRS
 Definition window, the modification to the parameters remains, but the
 name has changed back to the old name.  This problem happens in version
 1.4.0 also.
 My exact actions are
 Click yellow star (presumably the "New" button in Help)
 Type in name and parameters
 Copy parameters to test area, and if it works click OK (presumably the
 "Save" button in Help).
 Example of parameters used
 +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100010
 +ellps=airy +towgs84=375,-111,431,0,0,0,0 +units=m +no_defs
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2823>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
