[QGIS-trac] Re: [Quantum GIS] #2838: allow add existing layers to existing SL dbs (was: allow create spatialite/rasterlite from scratch and add existing layers to existing SL dbs)
Quantum GIS qgis at qgis.org
Sat Jun 26 15:45:50 EDT 2010
        Reporter:  lutra                             |         Owner:  nobody
            Type:  enhancement                       |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.6.0
       Component:  Data Provider                     |       Version:  HEAD
      Resolution:  invalid                           |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by lutra):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [comment:3 jef]:
 > Create a spatialite layer, click the '...' button next to the database
 combobox and select the name of the new database.
 ok, that was under my nose...
 The add "add existing layers to existing SL dbs" should be covered by the
 "spatialte manager" plugin that is under development.
 In any case I leave here a suggestion: allow creating SL db out of the
 "Create a spatialite layer" dialog. Hopefully sooner or later we will have
 the feature to allow add rasters to the SL db, so creating an empty db
 trough the "create a spatialite  (vector) layer" will not be really
 straightforward.
 cheers
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2838#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
