[QGIS-trac] Re: [Quantum GIS] #2839: add rasterlite support in "add spatialite layer" or add new button "add rasterlite layer"
Quantum GIS qgis at qgis.org
Mon Jun 28 03:15:34 EDT 2010
rasterlite layer"
   Reporter:  lutra             |              Owner:  nobody
       Type:  enhancement       |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.6.0
  Component:  Data Provider     |            Version:  Trunk
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
Changes (by jef):
  * platform:  Debian => All
Old description:
> Tested with rasterlite sample datasets.
> Add a rasterlite db (containing just one layer, otherwise you'll hit
> #1040) trough the "add raster layer" dialog. It will show fine.
> If you add it trough the "add spatialite layer" it will be "seen" as a
> vector feature and it will be added a polygon with the extent of the
> raster map.
New description:
 #1040) through the "add raster layer" dialog. It will show fine.
 If you add it through the "add spatialite layer" it will be "seen" as a
 raster map.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2839#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
