[QGIS-trac] Re: [Quantum GIS] #2475: Segmentation Fault in 1.4, opensuse 11.2
Quantum GIS qgis at qgis.org
Mon Jun 28 09:00:32 EDT 2010
        Reporter:  jtornero                                   |         Owner:  nobody
            Type:  bug                                        |        Status:  reopened
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.6.0
       Component:  Python plugins and bindings                |       Version:  1.4.0
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  SuSE
        Must_fix:  Yes                                        |   Status_info:  1
Comment(by jtornero):
 Replying to [comment:10 jef]:
 > Replying to [comment:9 jtornero]:
 > > Well, I've upgraded to KDE 4.4 but I still have the problem. I don't
 know where to "touch" or look now, any suggestions would be appreciated.
 > The backtrace looks PostgreSQL related.  Have you installed any
 additional PostgreSQL stuff?  I don't known (recent versions of) SuSE, but
 {{{/opt/PostgresPlus/8.4SS/psqlODBC/lib/libcrypto.so.4}}} doesn't look
 standard.
 > Do you have any (possibly postgres related) third party plugins
 installed?  If so, please check if the problem also appears without them
 and if it doesn't try to figure out which plugin is causing this.
 Hello,
 I've installed PostgreSQL plus standard server 8.4 from enterpriseDB
 repository instead of the one provided by openSUSE mostly because it
 really works fine from zero. I'll try to check in a computer without this
 distribution and also with standard postgresql installation if the bug
 occurs as well.
 Best regards
 Jorge Tornero
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2475#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
