[QGIS-trac] [Quantum GIS] #2845: QGIS won't compile with python
Quantum GIS qgis at qgis.org
Tue Jun 29 03:03:35 EDT 2010
   Reporter:  Alexbit                           |              Owner:  borysiasty
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Python plugins and bindings       |            Version:
   Keywords:  python bindings                   |   Platform_version:  Linux
   Platform:  Linux                             |           Must_fix:  Yes
Status_info:  0                                 |
 If you tray to compiling any version of qgis diffrente from svn trunk on
 Archlinux (Linux 2.6.34-ARCH #1 SMP PREEMPT i686 Intel(R) Pentium(R) D CPU
 3.20GHz GenuineIntel GNU/Linux whit KDE 4.4.4) you're unable to bind with
 python so you cannot get the fetch python plugin menu for install plug-in.
 I've try on the same machine (see above) with stable and develop but, as I
 say, only svn compile with no error and python bindings.
 Same situation on a laptop with analog software config.
 Moreover, also svn need to be manually patch at line 1051 of
 src/app/composer/qgscomposer.cpp. by changing if ( splitterState !=
 QVariant::QVariant() ) in if ( splitterState != QVariant() )
 Thank you for the attention.
 Best regards,
 Alessio
 PS: sorry if I miss details but i'm not a programmer. If you need more
 info tell me how I can I send that to you (alessiob(AT)gmail.com
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2845>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
