[QGIS-trac] Re: [Quantum GIS] #2845: QGIS won't compile with python
Quantum GIS qgis at qgis.org
Tue Jun 29 04:22:10 EDT 2010
   Reporter:  Alexbit                           |              Owner:  borysiasty
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Python plugins and bindings       |            Version:
   Keywords:  python bindings                   |   Platform_version:  Linux
   Platform:  Linux                             |           Must_fix:  No
Status_info:  1                                 |
Comment(by jef):
 Replying to [comment:3 Alexbit]:
 > If it's usefull for you:
 > This is the output of ccmake for stable (1.0.x):
 Python libraries found
 SIP is required in version 4.7 or later!
 Python bindings disabled due dependency problems!
 > This is the output of ccmake for develop (1.4.x)
 > This is the output of ccmake for SVN (1.5.x):
 Found Python library: /usr/lib/libpython2.6.so
 Found SIP version: 4.10.2
 Found PyQt4 version: 4.7.3
 Ok, so python support is only builtin for 1.5.  Earlier version probably
 just don't detect that SIP 4.10 is newer than 4.7 (see also #2446).
 Anyway, what (runtime) errors do you get regarding the python support with
 1.5?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2845#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
