[QGIS-trac] [Quantum GIS] #2544: shape export with custom CRS
Quantum GIS qgis at qgis.org
Thu Mar 11 08:01:46 EST 2010
   Reporter:  zawardo                                    |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.5.0
  Component:  Build/Install                              |            Version:  1.4.0
   Keywords:  export shp                                 |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  No
Status_info:  0                                          |
 I've an issue, when i try to save a postgis layer into a shp using a
 custom projection (gauss boaga fixed from the broken EPSG default record).
 The saved .shp is totally broken; if i save using a standard EPSG CRS
 (like wgs84) it works well.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2544>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
