[QGIS-trac] Re: [Quantum GIS] #2597: Adding layer is changed the last extent
Quantum GIS qgis at qgis.org
Sun Mar 28 07:45:17 EDT 2010
        Reporter:  aperi2007                         |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.5.0
       Component:  MapCanvas                         |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:  7                                 |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by aperi2007):
 I tested it on winXP 32bit and on win7 ultimate 64bit.
 I confirm the bug :(
 I try even to change the international settings (in italy we use the , for
 decimal).
 But both the case the bug is always.
 I put the shapefile I'm using for this testing.
 https://trac.osgeo.org/qgis/attachment/ticket/2597/esempio.zip
 Replying to [comment:3 lutra]:
 > Hi,
 > tested again under win Seven (ultimate 32 bit)/Linux with a 3003
 dataset, and still not confirming the behaviour.
 > Can you test on another machine and/or send a sample dataset?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2597#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
