[QGIS-trac] Re: [Quantum GIS] #3154: SVG Patterns: References to SVG files should start with pattern/symbol repository when paths are set to relative
Quantum GIS qgis at qgis.org
Mon Nov 1 06:16:24 EDT 2010
        Reporter:  neumann           |         Owner:  nobody
            Type:  bug               |        Status:  reopened
        Priority:  minor: annoyance  |     Milestone:  Version 1.6.0
       Component:  Symbology         |       Version:
      Resolution:                    |      Keywords:
Platform_version:                    |      Platform:  All
        Must_fix:  No                |   Status_info:  0
Changes (by neumann):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 I tested this fix on Linux. It works with paths relative from the default
 system (/usr/local/share/qgis/svg) but not from user-specified paths, set
 in "Options" --> "Rendering & SVG" --> "SVG paths".
 It would be great if this could work with user-defined paths as well.
 In my tests QGIS introduced absolute paths in the .qgs project file,
 instead of relative ones when picking SVG symbols from a user defined SVG
 directory.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3154#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
