[QGIS-trac] Re: [Quantum GIS] #3188: Bug in delimited text plugin
Quantum GIS qgis at qgis.org
Thu Nov 4 18:50:02 EDT 2010
        Reporter:  ccrook                                     |         Owner:  jef
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.6.0
       Component:  C++ Plugins                                |       Version:  Trunk
      Resolution:  fixed                                      |      Keywords:  delimited text plugin
Platform_version:  Windows XP SP 3                            |      Platform:  Windows
        Must_fix:  Yes                                        |   Status_info:  0
Changes (by jef):
  * status:  new => closed
  * resolution:  => fixed
Old description:
> Accessing attributes in a delimited text file layer causes QGIS to crash.
> Steps to repeat.
> 1) Open QGIS in a new project
> 2) Select a project CRS with parameters
> +proj=merc +lon_0=0 +lat_ts=0 +x_0=0 +y_0=0 +a=6378137 +b=6378137
> +units=m +no_defs
> 3) Click the delimited text plugin and enter
>    text file: attached file test.txt
>    layer name: text
>    delimiter string: \t, plain characters
>    X field: x   Y field: y
>    click OK
> 4) Map should display 3 points
> 5) Right click layer in the layers list and select "Open attribute table"
> QGIS dies with the Windows 'Send error report' dialog.
> Operating system: MS Windows XP, service pack 3
> QGIS version: 1.6.0 - build 14500
New description:
 Steps to repeat.
 1. Open QGIS in a new project
 1. Select a project CRS with parameters
 {{{+proj=merc +lon_0=0 +lat_ts=0 +x_0=0 +y_0=0 +a=6378137 +b=6378137
 +units=m +no_defs}}}
 1. Click the delimited text plugin and enter text file: attached file
 test.txt
   layer name: text
   click OK
 1. Map should display 3 points
 1. Right click layer in the layers list and select "Open attribute table"
Comment:
 fixed in r14507.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3188#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
