[QGIS-trac] Re: [Quantum GIS] #3126: Sliver holes remain after dissolve
Quantum GIS qgis at qgis.org
Mon Nov 8 18:44:12 EST 2010
        Reporter:  gislab                            |         Owner:  jef
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.6.0
       Component:  Vectors                           |       Version:  Trunk
      Resolution:  invalid                           |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment(by cfarmer):
 From a relatively quick Googling around, it appears as though GEOS *does
 not* employ any sort of tolerance when performing unions (which is what
 dissolve uses). There was some talk about snap-rounding to fix *some*
 issues with slivers, but this isn't really a sure-fire fix. One way around
 these sorts of issues (similar to snap-rounding) could be to simply round
 off the geometry coordinates at some level. This would likely reduce the
 number of high-precision slivers, but wouldn't get ride of all of them,
 and might not be great in cases where a high level of precision is needed
 (i.e. the distortion might be too large).
 Carson
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3126#comment:15>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
