[QGIS-trac] [Quantum GIS] #3216: WMS not working correctly
Quantum GIS qgis at qgis.org
Mon Nov 15 08:20:06 EST 2010
   Reporter:  pinux                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Data Provider                     |            Version:
   Keywords:  WMS                               |   Platform_version:
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
 This mapfile is working without problems on qgis 1.4:
 MAP
   NAME my_map
   SIZE 640 640
   UNITS meters
   EXTENT 5387500.000000 4989000.000000 5401000.000000 5007000.000000
   IMAGECOLOR 255 255 255
   IMAGEQUALITY 100
   IMAGETYPE jpeg
 PROJECTION
         "init=epsg:900913"
 END
 OUTPUTFORMAT
   NAME jpeg
   DRIVER "GD/JPEG"
   MIMETYPE "image/jpeg"
   IMAGEMODE RGB
   EXTENSION "jpg"
 END
    MAXSIZE 4096
   WEB
     IMAGEPATH 'C:/tmp/'
     IMAGEURL 'C:/tmp/'
     # WMS server settings
     METADATA
       'wms_title'           'My layer'
       'wms_onlineresource' 'http://localhost/cgi-
 bin/mapserv.exe?map=C:\my_map.map'
       'wms_srs'             'EPSG:900913'
     END
   END
   LAYER
    PROCESSING "RESAMPLE=NEAREST"
     NAME "My map"
     STATUS ON
     TILEINDEX "index.shp"
     TILEITEM "Location"
     TYPE RASTER
     METADATA
       'wms_title' 'My Layer map'
     END
     STATUS DEFAULT
     TRANSPARENCY 100
   END
 END
 From 1.5 to the trunk r14547 I'm having the following problems:[[BR]]
 1. When I try to select the layer under the number 1 it is automatically
 selecting the name of my map under number 0. It happens even when I have
 more than 1 layer.[[BR]]
 2. The output format is not automatically selected to jpg like it was
 working on qgis 1.4.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3216>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
