[QGIS-trac] Re: [Quantum GIS] #2921: Avoid intersection of new polygons.. IS BROKEN
Quantum GIS qgis at qgis.org
Thu Nov 18 17:11:41 EST 2010
   Reporter:  pinux                                      |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.6.0
  Component:  Digitising                                 |            Version:  1.5.0
   Keywords:  intersection, polygons                     |   Platform_version:
   Platform:  Windows                                    |           Must_fix:  Yes
Status_info:  0                                          |
Comment(by pinux):
 Replying to [comment:1 mhugent]:
 > I cannot entirely follow your description. Do you mean that the merge
 tool and avoid intersection tools don't work with invalid geometries? And
 after you fixed the geometry errors on the polygons, it did work?
 > If yes, that's the behaviour I would expect. Because merge and avoid
 intersection use geos and I'm pretty sure it does not do union or
 difference on invalid geometries. Maybe postgis tests the geometries first
 and tries to fix them automatically?
 My problem is not with the merge, when I was trying to merge polygons that
 I had digitized with the option "Avoid intersection of new polygons" I had
 some errors. So i have made some view to understand what was happening
 with my data.
 And I have found that the option "Avoid intersection of new polygons" is
 not working correctly:[[BR]]
 1. If I do an union in postgis I have 2 holes,[[BR]]
 2. Polygons are overlapping;[[BR]]
 3. Polygons with multiple ring, even if I don't have digitized polygons
 with multiple rings.[[BR]]
 If you load the sql that I have uploaded you will see what I'm talking
 about.[[BR]]
 The result with 12 polygons:[[BR]]
 - union with 2 holes[[BR]]
 - 9 polygons are overlapping[[BR]]
 - 2 polygon with multiple ring[[BR]]
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2921#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
