[QGIS-trac] Re: [Quantum GIS] #3222: Fast, easy and beautiful on the fly rule-based rendering of OSM maps
Quantum GIS qgis at qgis.org
Sun Nov 21 16:29:05 EST 2010
   Reporter:  mayeulk                           |              Owner:  nobody
       Type:  enhancement                       |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Symbology                         |            Version:
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Comment(by mayeulk):
 Attached below a first release for a set of rules. In addition to visual
 quality control (on part of Northern Italy) for scales between 1:5,000 and
 1:20,000,000, I wrote a script to make some statistical control with an
 entire country (Italy): For lines, 98% of Italian ways in italy.osm planet
 file would be symbolized (most of the lines not matched by any rule are
 unclosed polygons that should normally be rendered as polygons, for
 instance: "landuse"="farmyard", "natural"="land", etc.). There is still
 room for progress of course.[[BR]]
 I have no statistics on polygons and points yet.
 To use the rules, best if you have ''four'' layers:[[BR]]
 1. points[[BR]]
 2. polygons[[BR]]
 3. lines[[BR]]
 4. polygons
 Layer 2 (top polygon layer) is used mainly for closed highways (such as
 roundabout) that the QGIS osm-to-layer converter converts to polygons.
 Rendering is ugly without this layer in many areas (fun example here:
 [http://osm.org/go/0CheErNHu-/ roundabouts near Malpensa airport]; I could
 not have a nice result with only 3 layers).
 The lines layer uses symbol levels. It will look ugly without the full
 patch mentioned here: ticket:2832#comment:8
 Beware: you have to activate symbol levels BEFORE opening the
 highway_all_rules_v34.qml file. If you modify the rules and save them, you
 have to add  ' symbollevels="1" ' (without the single quotes) after '
 <renderer-v2 ' on the forth line of the qml file.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3222#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
