[QGIS-trac] [Quantum GIS] #3253: Enhancement: option to "trim other
layers to match"
Quantum GIS
qgis at qgis.org
Wed Nov 24 21:23:09 EST 2010
#3253: Enhancement: option to "trim other layers to match"
Reporter: Alister | Owner: nobody
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone: Version 2.0.0
Component: Symbology | Version:
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
'''Task:'''
It would be useful to be able to use a polygon to temporarily mask other
layers.
e.g. if you have a layer of boundaries for catchments (or provinces or
something), to only display content within one particular catchment.
'''Current way of achieving the task:'''
I think the most flexible way to achieve this at the moment is:
1. create a set of new mask layers, by subtracting each catchment from a
polygon bigger than the area of interest.
2. put these layers above everything else.
3. only turn on the mask layer which corresponds to the area of interest.
This method is fine for the work I do myself, because I work with only a
small number of areas. But it would not be practical with a large number.
'''Proposed new feature'''
I think the best way to do it would be to add an option "trim other layers
to extent" (there is probably a better way of wording this - some people
might think "extent" implies a rectangular area or something).
This would allow the user to mask all map content outside a polygon layer
or whatever subset of the layer is defined (by the query builder).
A logical place for the option would be on the "general" tab in the "layer
properties" dialogue, as this is where the layer subset is shown.
N.B. sorry if I haven't picked the appropriate Component; I'm not sure
which it should be.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3253>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
