[QGIS-trac] [Quantum GIS] #3096: Silent install is not possible when used to upgrade QGIS
Quantum GIS qgis at qgis.org
Fri Oct 8 07:49:53 EDT 2010
   Reporter:  asgerpetersen                     |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Build/Install                     |            Version:
   Keywords:                                    |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 When running the windows standalone installer with the silent switch (/S)
 on a system with an earlier version of QGIS, the installer is not silent
 as it shows a dialog box to confirm the upgrade. This is especially a
 problem with the installer is running as part of a startup script, because
 then the dialog is hidden. This prohibits central administration of QGIS
 in a Windows environment.
 Command used: QGIS-OSGeo4W-1.5.0-14109-Setup.exe /S
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3096>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
