[QGIS-trac] Re: [Quantum GIS] #2976: Wrong properties display for GRASS Raster
Quantum GIS qgis at qgis.org
Fri Sep 3 03:47:48 EDT 2010
   Reporter:  jrm                               |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  GUI                               |            Version:  1.5.0
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
Comment(by lutra):
 Replying to [ticket:2976 jrm]:
 > Properties of a GRASS raster are limited by defaut to
 Transparency/General/Metadata as the user can't modify things like color
 table without using grass' r.color.* tools
 this is because the GRASS rasters are no longer handled via GDAL. So you
 really need to have to use GRASS tools to configure/style them.
  but after loading non-grass raster, QGIS then display all the properties.
 > This behavior leads user to think that QGIS or their grass raster is
 broken, for example the grass raster display list with no item selected.
 > Steps to reproduce :
 > 1. create a new project and open a grass dataset
 > 2. load a grass raster, open its properties, then close it
 > 3. load a non-grass raster, open its properties, then close it
 > 4. reopen the grass' properties, it is now displaying the same ui than
 the non-grass raster
 confirmed. It is just enough to open the GRASS raster properties in QGIS,
 close the dialog and then reopen again.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2976#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
