[QGIS-trac] [Quantum GIS] #2983: New Gamma Parameter For Oblique mercator Not Accepted
Quantum GIS qgis at qgis.org
Mon Sep 6 08:35:26 EDT 2010
   Reporter:  alexckp                           |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Projection Support                |            Version:  Trunk
   Keywords:                                    |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 Frank Warmerdam recently updated the proj4 trunk codes for OSgeo4w to
 enable the gamma parameter. I downloaded the latest nightly qgis build and
 found the gamma parameter works when using custom crs test box. I was also
 able to save the newly defined parameters as a customized crs.
 However, when I checked the parameters in the layer properties, the gamma
 parameter is still somehow rejected and I am therefore still unable to
 reproject the layer to wgs84 coordinates. Could it be that the proj4 codes
 are not properly compiled into the nightly build?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2983>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
