[QGIS-trac] Re: [Quantum GIS] #2985: qgis broken with new py-sip
Quantum GIS qgis at qgis.org
Sat Sep 11 19:04:19 EDT 2010
   Reporter:  jasperla                          |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Build/Install                     |            Version:  1.5.0
   Keywords:  sip build failure                 |   Platform_version:
   Platform:  OpenBSD                           |           Must_fix:  Yes
Status_info:  0                                 |
Comment(by volter):
 Doesn't work for me with QGIS 1.5, SIP 4.11 and Qt 4.7:
 [ 95%] Generating ui_qgsplugininstallerbase.py
 cd /builddir/build/BUILD/qgis-1.5.0/python/plugins/plugin_installer &&
 /usr/bin/pyuic4 /builddir/build/BUILD/qgi
 s-1.5.0/python/plugins/plugin_installer/qgsplugininstallerbase.ui -o
 gins/plugin_installer/ui_qgsplugininstallerbase.py
 An unexpected error occurred.
 Check that you are using the latest version of PyQt and send an error
 report to
 support at riverbankcomputing.com, including the following information:
   * your version of PyQt (4.7.6)
   * the UI file that caused this error
   * the debug output of pyuic4 (use the -d flag when calling pyuic4)
 make[2]: Leaving directory `/builddir/build/BUILD/qgis-1.5.0'
 make[1]: Leaving directory `/builddir/build/BUILD/qgis-1.5.0'
 make[2]: ***
 [python/plugins/plugin_installer/ui_qgsplugininstallerbase.py] Error 1
 make[1]: ***
 [python/plugins/plugin_installer/CMakeFiles/pluginstaller.dir/all] Error 2
 make: *** [all] Error 2
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2985#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
