[QGIS-trac] [Quantum GIS] #3022: vertex markers disappear when clicking the "save edits" icon plus a more serious issue
Quantum GIS qgis at qgis.org
Sun Sep 19 07:21:33 EDT 2010
serious issue
   Reporter:  lutra                                      |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.6.0
  Component:  Digitising                                 |            Version:  Trunk
   Keywords:                                             |   Platform_version:
   Platform:  All                                        |           Must_fix:  Yes
Status_info:  0                                          |
 Pick a vector, toggle editing, make a change (like moving a feature) and
 then click "save edits", the vertex markers will disappear.
 If you make this test with the "node tool", for example moving a node, the
 resulting effect is even worst:
 select a line or a polygon with the "node tools", move a vertex and click
 "save edits". The vertex markers will disappear.
 Now move again a vertex: the blue square will move, but the adjacent lines
 will not (at this point you can try save edits but it will be as the
 vertex wasn't moved).
 This happens only the first time you try move a vertex, because if you try
 again the tool will work fine.
 Tested with trunk under both linux and windows.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3022>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
