[QGIS-trac] Re: [Quantum GIS] #3032: Diagram overlay and trunk not building
Quantum GIS qgis at qgis.org
Tue Sep 21 15:31:47 EDT 2010
   Reporter:  jctull                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.6.0
  Component:  Build/Install                     |            Version:  Trunk
   Keywords:  diagram overlay build             |   Platform_version:  10.6.4
   Platform:  OS X                              |           Must_fix:  Yes
Status_info:  0                                 |
Old description:
> The diagram overlay plugin is not compiling at this time in trunk. Here
> is the error message:
> Scanning dependencies of target diagramoverlay
> [ 79%] Building CXX object
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramdialog.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramcategory.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramfactory.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgswkndiagramfactory.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgswkndiagramfactorywidget.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsbardiagramfactory.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgspiediagramfactory.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgssvgdiagramfactory.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgssvgdiagramfactorywidget.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramfactorywidget.cpp.o
> [ 80%] Building CXX object
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramoverlay.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramoverlayplugin.cpp.o
> src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramrenderer.cpp.o
> /bin/sh: line 1: 69883 Segmentation fault      /usr/local/bin/ccache g++
> -Ddiagramoverlay_EXPORTS -DQT_SVG_LIB -DQT_WEBKIT_LIB -DQT_GUI_LIB
> -DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB
> -DQT_NO_CAST_TO_ASCII -DQT_NO_DEBUG -O3 -DNDEBUG -arch x86_64 -fPIC
> -F/Library/Frameworks -I/Library/Frameworks/QtSvg.framework/Headers
> -I/Library/Frameworks/QtWebKit.framework/Headers
> -I/Library/Frameworks/QtGui.framework/Headers
> -I/Library/Frameworks/QtXml.framework/Headers
> -I/Library/Frameworks/QtSql.framework/Headers
> -I/Library/Frameworks/QtNetwork.framework/Headers
> -I/Library/Frameworks/QtCore.framework/Headers
> -I/Users/jctull/sources/qgis/trunk/build
> -I/Users/jctull/sources/qgis/trunk/build/src/plugins/diagram_overlay
> -I/Library/Frameworks/GEOS.framework/Headers
> -I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core
> -I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core/pal
> -I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core/raster
> -I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core/renderer
> -I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../core/symbology
> -I/Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/../../gui
> -DCORE_EXPORT= -DGUI_EXPORT= -DPYTHON_EXPORT= -DANALYSIS_EXPORT= -o
> CMakeFiles/diagramoverlay.dir/qgsdiagramrenderer.cpp.o -c
> /Users/jctull/sources/qgis/trunk/src/plugins/diagram_overlay/qgsdiagramrenderer.cpp
> make[2]: ***
> [src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/qgsdiagramrenderer.cpp.o]
> Error 139
> make[1]: ***
> [src/plugins/diagram_overlay/CMakeFiles/diagramoverlay.dir/all] Error 2
> make: *** [all] Error 2
New description:
 The diagram overlay plugin is not compiling at this time in trunk. Here is
 the error message:
 make[2]: ***
 Error 139
 make[1]: ***
Comment(by jef):
 Replying to [ticket:3032 jctull]:
 > make[2]: ***
 Error 139
 > make[1]: ***
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3032#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
